I had to reset my sky box today and, it seems, as a result I am now getting a network error message when I try to view internet video content. I've checked my network status and it says I'm connected, and my internet browser on the tv is working fine; I just seem to be having trouble with the internet video content (i.e. BBC iPlayer, YouTube, etc.) I have a Sony Bravia KDL-40NX723. can anyone help?
Thanks.
i've fix the pb with youtube vidéos
Hello,
The below steps may help to fix the problem
1- navigate through HOME (menu) to find the network and select refresh internet content
2- if the above step not help, then do a factory resetting for TV and repeat the 1st step again (pls be aware that you will lost all stored channels, picture and sound setting which will back to the factory setting out of the box).
At any time press the i-manual key on the remote to get on-screen help
Below is the link for your TV owner manual
Thaks for posting this - hopefully this will help out others who are suffering...
cheers
How do I fix a network error message on my Bravia TV. I am unable to access any of the apps.
Thank you
Hi there
More information is required in order to help you. The error message would certainly help, and so would the model of your TV. Also any other relevent details.
model 65s8005c3d
Hi @malchap
Thank you for posting the model number of your TV - however your model number indicates that you have an Android based TV. If you have an issue, can you please create a new post under the "Android TV" section, including all and any relevent information.
Reading other posts I cannot access internet channels for catch.. message says error occurred please try later. Please help.
