Just bought the Bravia. I have used Sennheiser headphones previously as am hard of hearing. These enable me to listen at a higher volume while others listen to the set at a lower volume. Applying these to the new product seems to suppress all sound from the set and produces nothing from the headphones. Any set up advice please?
Hi oldieal,
Have a look here for further help.
Let me know how you get on.
Thanks,
Sean Mc
Hi oldieal,
Thanks,
Sean Mc
Many thanks. I will investigate further.
I’ve a newborn so looking to finally pair my bt Nc headphones to my beautiful tv. It will not find them though. The link in this reply is no longer working, can I get some pointers please?
Unfortunately your TV has the following BT profiles
Bluetooth Versione 4.1 (HID / HOGP / SPP)
So it doesn't support A2DP for headphone connection
