A friend of mine is using 1 TB HDD drive for PVR recording for a longer time. Few days ago this drive became unavailable, just like it was unregistered from his TV. I think it wasn't his fault, he didn't play with menus and so on. Could it had happened by electrical discharge?
My question: is it possible to re-register this drive but without losing many, many TV recordings?
In some cases it is possible to get back to our recordings.
I checked that disc. Sony uses kind of NTFS file system on PVR discs. I wrote "kind of" because my Linux doesn't recognize it as a proper NTFS file system. There were some errors but with Win 10 and fixing with chkdsk it went like a charm. I solved my problem this way:
1) I did backup of all files (normal copy and 1:1 disc image)
2) I formatted PVR disc
3) Plugged disc into TV, registered it and made few fresh recordings
4) Unplugged disc without unregistering and connected to my Windows machine
I noticed some differences between old disc image and the new one.
The old one had one additional CONTENTS folder (with 1970s date!) and a file .device_info_2840a*
The new one had that structure:Fresh PVR structure
So the only thing I had to do:
1) delete these unnecessary folder and file,
2) copy original old structure, but without selfrec.reg
I think this file contains last disc registered data, because binary content was a little bit different from the old one.
3) I plugged disc to turned off TV and all these old recordings were playable!
Hi Glider80,
Welcome to the Community. You could always try asking Sony Support about this.
Thanks,
Pascale
Hi Pascale_F,
Thanks for tip. I asked and they answered – it cannot be undone 😞
I'll ask my friend, he's working with discs for years – maybe some mirror copy, new filesystem and then again moving data will work 🙂
