Hi all,
just a quick question about the freeview HD channels, I used to recieve them on my fine on my previous set KDL-37EX723 but the picture is breaking up and cutting out on the HX or it just doesn't appear at all.
Take BBC1 HD for example; on the system information page the signal quality is 0 & the strength is 8 or 9 and theres a tiny bit of red on the bar so by the information here the aerial isn't up to scratch.
However I've changed nothing with my aerial so I thought it could possibly be the TV itself. Will an aerial signal booster improve the signal enough ? I really don't want to have to get up on my roof and mess around unless I have no choice ...
Any help is appreciated !
i have a similar experience with HD channels and my aerial is good!, i was told by an installation engineer to hold on till the new year when the transmitters have stopped faffing about with HD testing and see if things improve, i have a signal strength of 30 but the quality is 100 but only on HD, on standard freeview they are both on 100, i may even consider changing my aerial again at a last resort, but it may improve yours if its never been done.
Hi
Strange - have you updated the firmware on the TV? There have been several updates since release which may have improved things...
Thanks
ho do scan for all channels using my sony remote
