I have 2 old TVs - KDL20S4000 & KDL26S3000 - as of this morning (1st Jan 2021) the reminder function on the EPG stopped working. When I try to set the reminder I get an error message saying "This event data is invalid". I use the reminder function a lot to plan my viewing. How do I get ***** working again?
No luck with mine either I'm afraid... 😕
Hi Win_88
Please can you post here if you see a fix on Twitter, as I don't use it
Thanks
Gardenfairy
Return of the millennium bug due to quick cheap fix.
Would have been ok for analogue only TV's that would be scrapped (about 2005) . Caught with their pants down if they carried on using the code for digital sets.
So only a TV firmware update will fix this issue.
Will Sony issue affected users with one to flash via the memory stick service slot? I very much doubt it, the last update was nearly 10 years ago, and as that article mentions the people responsible for the TV software could be / are long gone. ☹️
My TV set has no external input for a memory stick. I suppose fifteen years service is the best I can hope for.
What software version do people have on their TV?
Mines on: 2.12.102
Searching around it looks like Germany had a two further updates than the UK, their highest seems to be version: 2.12.108
Did you check near the CI module slot like an earlier post mentioned? I didn't even know my TV had a memory stick slot until I read it.
Are you in the UK?
I wonder why I've only got .102 installed, auto update has always been set on 🤔
