Digital tv quality
SOLVED
profile.country.en_GB.title
shahab
Visitor
Digital tv quality
hello,
I had a question about digital signal receiving that is possible with (ie.) DVB receiver;
I'd  like to know wether sony kdl-40v5500 has a digital receiver inside or not; if yes, please help me & describe how should I use it?
it will be very good if you send your answer to my e-mail.
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
Hi - yes it has a DVB-T tuner integrated..
Thanks
2 REPLIES 2
Bravia55HX
Member
your set is fitted with a digital tuner, if you have not done so you may need to re tune to the digital switchover, once done you just use the tv like you normally would.
i should add that you may need to check your aerial as you may need to update this to a new Digital one.
Catmambo
Contributor
Thanks
