Hello,
I would like to find out what is the maximum length Ethernet cable for bravia TV? Thanks
My understanding is the generally accepted max is 100m without the need for a powered switch or repeater. This is not a Sony limitation, more a standards limitiation though
http://www.wirelessforums.org/alt-comp-hardware/maximum-ethernet-distance-10531.html
Hope this helps
Hope this helps
