Purchased the CX523 yesterday. The grid view for the Internet channels is blank. It has grey boxes where the channel logos should be. It's very annoying as I have to check each box to see which channels are there. What's going on? Thanks
Try going to Settings on the TV, select network and then "Refresh Internet Content"
