On Tv. series the actors voices are the correct level but when there is "canned laughter" it is far too loud. Is there any way to balance this?
Is it only on some channels - broadcasters have fiddled with volume levels for years depending on what you are watching...
http://conversation.which.co.uk/technology/loud-tv-television-ad-advertisements-commercial/
Not anything you can change on the device and would be the same with any TV I think.
Thanks
Thanks
Thanks. Yes, with the adverts I can get to the remote in time but the "canned laughter" is in the program. Thought maybe different sounds on different speakers?
Sean.
