I was wondering if anyone can please help me. I've got a KDL46HX823BU LCD TV connected on HDMI 1, using a HDMI cable, to a STR-DH820 AV Amp connected to the HDMI output. Both these devices support the Bravia Sync control yet I cannot get the TV to discover the Amp.
Here's what I've tried so far.
STR-DH820
GUI Mode
Settings
HDMI
Ctrl for HDMI: ON
Pass Through: AUTO
Audio Out: TV+AMP
HMDI Assign: Greyed out (Not in Use)
KDL46HX823BU
Home
Settings
External Inputs
HDMI Set-up
Control for HDMI: On
Auto Devices Off: On
Auto TV On: On
HDMI Device List
Enabled
No devices detected. Please check the connection of settings of the device.
I'vr tried different HDMI cables, resetting both the TV and Amp back to factory defaults to no avail. I would be very grateful if anyone had any other suggestions please?
Thank you,
Jon
Jon,
I have a similar setup - same amp but NX713 tv.
My setup works but with slightly different amp settings:
Ctrl for HDMI: ON
Pass Through: OFF
Audio Out: AMP
Although, if the TV doesn't detect the Amp when you enable a scan through the device list, I'm guessing the settings won't matter?
You say you've tried other HDMI cables and this may be a long shot, but are your cables HDMI v1.4?
Hope that helps
Jp
Hi Jp,
Thanks for your feedback. I ordered a new 2m HDMI v1.4 cable which I tried earlier and Bravia Sync didn't detect that either.
I'll give your settings a go and get back to you.
Thanks again,
Jon
