This should sort you out -
Thanks
Thanks
Yes, an HDMI splitter will basically ensure you are getting a high quality digital signal and remove the need for you to have to switch cables between boxes. You may need to get an extra HDMI cable, as you'll need 3 with this setup though.
Thanks
