I am unable to access my NAS drive through the TV.
I attach a screenshot below of excerpts from the offical SONY operation manual for this exact TV model which states configuration of NAS drives can be done via a submenu called home network setup under the main network option.
As you can see from the photo below, I do not have the home network setup option available to me.
So despite the fact that I have the latest software update for the TV, and despite the fact that I've even tried a factory settings reset to see if it then comes up, for some reason my TV does not have the functionality claimed in the operating manual.
Some help with this would be great because it's making me tear my hair out. The NAS and it's embedded DNLA server has previously worked fine through this exact router to a Samsung TV.
The problem is the Sony product, somewhere.
bump.
Hi @onevalefan - I have escalated your post for you, so someone from Support should be in touch soon to help you.
Cheers,
C
Hi @onevalefan
We just heard back from Support and they advise to switch from IPV6 to IPV4 as a test.
However, this is a non-European model, so they can't really support as much as they can with UK models.
Best,
Arthur
Hi @Anonymous
Thanks for that.
Unfortunatley it has had no effect.
bump
Hi there,
We've let the Support Team know that the previous advice hasn't helped, and we've asked them for further assistance. We hope to have a response for you soon.
Thanks,
Owen
Hi onevalefan,
Unfortunately, since this is a non European model, Sony's support to the device, as well as its general functionality is limited, so they recommend you to contact the support team of the country of origin to verify if this network feature is even compatible with the network standards used in the UK.
Best wishes,
Pascale_F
