Currently waiting on my KDL50W829B being delivered, it is ab upgrade from my 50" LG Plasma.
Having a problem with fitment on my current tv stand though as judging by the pictures of rear of sony tv it is completely different. At the moment i have two bars screwed in either side of the lg tv and then it hooks in on a swivel stand. does anyone have any idea if there are any brackets i can get to fit the new sony tv on the stand i have included a pic below to show how it is currently set up.
Really dont want it on the standard stand on the unit as there wont be a big enough gap to put the surround sound centre speaker and also the tv wouldnt swivel.
Any help would be appreciated.
[IMG]http://i60.photobucket.com/albums/h2/callum929/photo-1.jpg[/IMG][/URL]
Hi there
From my understanding the W829 model includes a stand that is reversable to wall mount, however the TV is not VESA compatible. However there may be a bracket that can be added to make it so, and hence mountable on your stand. I advise you to call Sony Support and enquire about a bracket for the W829 for mounting on a VESA stand.
For contact details, see : HERE
Hi there
