I have a Bravia KDL32W654 bought in October 2013. I cannot get BBC i-Player despite latest updates and confirmed internet access. I can receive some other on-line facilities so I know the connection is there. Any suggestions ?
Hi there
Try the following:
Hope that helps.
Hi there
Try the following:
Hope that helps.
Thank you so much for taking the time to help AND IT WORKED. Went through in the order you suggested but it was finally factory reset that was needed - made me feel I wasn't being so daft after all.
