Hello. I have a Sony Bravia TV and new MDR-RF895RK headphones. I can connect the headphones ok but can find no way to switch between them if I want to go back to the TV speakers, apart from unplugging the cable from the back of the TV (inconvenient). Nothing in the settings menu to enable a switch. Feeling slightly ripped off - nothing at all in the menu or support guides. 🙂
does anyone know if there is an option to switch easily or would I be better returning the headphones ?
Any help to confirm would be welcome.
Thank you
Hi Sarah,
Welcome to the forum.
Can you tell us the model number of your TV so that we can look into this for you?
Thanks,
Ed
Hi Sarah,
Thanks for your model number. We'll check into this further and update you when we have more information.
Meanwhile, maybe some of our other members will have some experiences to share.
Best wishes,
Ed
Hi Sarahparis,
I think you can switch between both speakers. Have you tried to enable the TV speakers as follows: (HOME - System Settings - Setup - AV setup - Speakers - TV speakers)?
Let us know if this resolves it.
Vanilla_
