I've a Sony TV (Bravia KD-55X8505B ; fw PKG3.004EUA) since 2 years and I'm very happy about this product. However, since 2 weeks, apps are not working (not able to laucnh it) and if I try to install a new one, the list of apps is empty.
What I did until today:
- Update the TV fw but seems I have the latest one
- Check internet connection (using wifi) and all is good (recheck wifi password and IP and test the connection through network settings)
- Check the internet/wifi router details and just to make sure I put the IP address of the TV on the DMZ
Still not working... Any advise?
Thanks,
V.
Same issue here, no apps on both TVs
Thanks again. Feeling stubborn about this and will persist!
Since Friiday 19 Oct. 2018 I lost all the apps. I have tried each and every solution on here and elsewhere on the internet for this persitent & recurrng issue and none work.
My set is less than 1 year old
model~ DKL-32D756
S.W. Version: 8213-1000-1.330-01
Netflix works perfectly.
Down to you Sony...
I've just emailed all details to watchdog let see if we get an answer from Sony soon
Agree Sony fix this issue!!!!!!
Me too, a couple of us have contacted Watchdog to see if Sony can be shamed into doing something to help?!
I'm hoping that their technical support will be able to sort it???
I have also contacted Watchdog! If more people do this, maybe something will be done to help?
