I have a Bravia KDL-40EX403 tv and would like to add Netflix as an internet option, how can I do it?
Hi there
The only way for you to get Netflix onto your TV, is to purchase another device (ie A Sony Blu-ray player, that has Netflix)
https://www.sony.co.uk/discussions/message/1265664
Hope that helps
Hi there
Hope that helps
Thanks Quinnicus
