Hi all,
Thinking of getting an Amazon Fire TV.
Which ports on the 79X9005B are HDCP 2.2 compatable?
Hi there
HDMI Ports 1 and 2 should have HDCP 2.2 enabled.
Thanks, is the replicator able to carry this capability?
Hi there
I can only assume so, as i cant find the exact specs. As you know, you plug a connected cable from the replicator to each port - from what i can gather, its just a pass through. Therefore i cannot see any reason why it those two ports would not be HDCP 2.2 compliant. Would be silly of Sony if it wasnt
