The TV seems to be less reliable at powering on in response to HDMI-CEC signals from devices since the latest update. It worked perfectly prior to this.
It will also *sometimes* power off my PS4 when I turn the screen off. If I press the Sync Menu button on the remote I can turn the PS4 off from here reliably every time.
Hi there
Can you try the following and see if it works
If that fails, can you please perform a factory reset of the TV. It can clear many issues especially after a FW update.
Hopefully that solves the problem. If not, please respond back.
