Hello Everybody,
Is anyone experiencing some issues with the X8,
I have a few problems with the X8 which I list below.
1. Downloading MMS settings does not work.
2. Some operator messages cannot be replied to.
3. The Music player does not have Playlist!!! This is such a let down. I don't want to be scrolling all the time to play another song.
4. When the phone syncs with address book from Google it deleted the contacts!
5. In Call volume is low, and the slider displayed shows there is some more volume left but it wont move anymore.
6. Can the SW prevent crucial things from getting uninstalled. I mean there are some system apps that could be uninstalled thay may cause the phone to brick out.
7. No Alert Profile are available, either silent or audible. Nothing like discreet or extra loud.
8. The Keypad slows down so significantly when the message thread is a bit long. It gets annoying to type. Also Some words need to be unlearnt.
Am I missing something as to how the phone shold be configured or what?
Other than that, the phone is awesome, great value for money. Although I wouldn't mind paying for a much higher spec version in the same form factor. I love my X8 more than this X10 or X10miniPro.
Thanks!
The first thing to try is running a software repair via Sony Ericsson Update Service, downloadable from the Support section of the website. This will wipe the phone so ensure that you have your contacts saved/synced. If it is a software problem this should resolve it.
If it does not help then I suggest that you take it back to where you bought it and ask for them for a replacement under warranty.
just 5 days since i bought this x8 phone..and i have these issues
->no playlist as suggested above and it is totally let down, even my 5 year old SE k750 has awesome playlists and equalizers....music and videos were fun....but dono why SE let this phone without these features...NO PLAYLIST, NO EQUALISER...totall let down
->the video playback is horrible...i used xilisoft mp4 convertor and converted my videos to 320*480 res and whenever i play any video it wont play more than 3-4 mins...it gets restarted automatically...i hate this phone like for this one reason, as i love SE for music and videos...and this phone makes me get very angry. I read somewhere here in the forum where they said internal memory is low for videos to play...if tat is the reason , why the HEll did SE release a video phone with 8gb support and 128 MB storage, 168 MB RAM....if they cant test the phone with the internal memory wats the reason in releasing it???
-?the phone gets stuck up and often doesnt load the apps
->the radio is also poor we cant tune the various radio stations with the volume button as in previous SE[ my old SE k750 had]
->the phone sound quality is not great...just very mediocre for a phone in this price segment...
->cant arrange the pictures in folders....when i click the album , all pics loads up just like tat...i wud like to have different folders when iclick album then by selecting the folder i shud be able to see the pics inside...now it loads all the pics at once....can this be solved??
will sony ericsson see this forum??? just 5 days since i bought this x8 and i have so many problems....this gives me a very bad opinion aboout SE...am sorry to say this...if these problems are not rectified....u lose ur Loyal customers SE....
I have the same issues with the screen going ''black'' as the above users. Seems like it is common issue among X8 sets. Though I recently discovered that for my case, it is not actually totally black but is still running (if you notice carefully, there may be some faded, vague image prints from the running applications on the screen). Instead of taking out the cover and battery, I happen to leave it in my pocket for a few minutes until it worked again. So it is actually just hanging or freezing terribly.
With regards to Google Talk, it does not allow you to delete a chat history after a conversation! Any help with this would be greatly appreciated!
Try using RockPlayer, download it from android market this plays almost all video formats with out any problem..i have used it and watched entire movies in x8 without any problem.and also check if the video is correctly converted by playing it in the computer once...There is no need for conversion as it can play all formats easily unless its high definition where there will be audio and video synchronization problem.
I repaired the phone... but the black screen issue is still reproducible. Yes, and the phone restarts for no reason. I had a couple of occasions when I wanted to make a call in front of my colleagues and it restarted. What an embarassment it was!!!
thats true the black screen may not be a problem always... but once i was using an SE supplied app, i tried to make an urgent call and then I saw the black screen... I took out the battery and made the call. I feel this is a serious issue. what if I actually needed to make a call in case of a critical emergency... Had that been the case, SE would have to pay dearly for it.
i faced the same issues, but I am waiting if the 2.1 update can fix them.... I assume its because of app incompatibility but still... should they have tested with at least all the Apps that come preloaded, even basic functions can cause the phone to freeze for some time... occasional leading to black screen and/or restart.
Cannot send files over Bluetooth also. A basic phone 4 years ago can do this!!!
Bluetooth File Transfer app from Medieval on Android Market .installed it today and it works fine but its more like a PC file manager, it will transfer anything.
