I have seen a web where says that the xperia u is waterproof, is it true?
i can understand a bit, it says yes because it has a IP67 certification..
I suggest that you inform the owner of the site of this mistake, as certainly Xperia U was not made water/dust resistant. and it could cause alot of problems for users.
thanks for the info
NO
the only waterproof Xperias are
Xperia Active, GX, Acro S, V
unrelated topic, if you have some time please check this thread
gee, this is getting more common one, I hope no one attempts dunking their XPeria U on water. can you provide the link?
http://versusio.com/es/sony-xperia-u-vs-apple-iphone-4-16gb u can use a translator because it's in spanish
| Es resistente al polvo y a prueba de agua (IP67) | Si | vs | No | Totalmente protegido contra el polvo (IP6x) y protegido contra la inmersión hasta 1m de profundidad (IPX7) |
i'll see the way to contact the owner of the site
thanks! I was about to try it xD!
lol you'll be a saviour for alot of Xperia U.
wow please do contact them because this info is horribly wrong, you can try gsmarena or phonearena next time to compare phones
imagines users deliberately trying underwater Xperia U stunts for testing/showing off the resistance and then the phone goes poof...hahahaha
