When battery reduce below 40%. It will change battery status from 40% to 1% and then shutdown automatically.
Does has any experience? or know how to fix. Please recommend me.
Thank you.
Charge to 100 %. Switch off then for 10 mins. And restart. Should solve the issue. Did you do this before?
Charge to 100%. Switch OFF. Keep like this for 10 mins. Switch ON. Most probably charge will be less than 100%, this is due to a small calibration mismatch. Its solved as of now. If you face this too much, repair using sony update service.
Hi Arnab,
I charged 100% every time. It's take the time about 1-1.30 hour to 100%.
No, I never did that before.
What you mean "switch off". You mean shutdown phone or unplug the charger?
Sorry for my english. And Thank you for your answer
shutdown phone
Hi arnab, It seem your solution is work.
Now my battery is 28% and it's not shutdown.
Thank a lot.
