Just updated my Xperia T...
Downloaded the update
Ran the update, the phone shutdown as usual... left it for a couple of hours.
When I came back to it it was seemingly off, I powered it on and since then it is in a reboot cycle!
It put up the Sony logo then the Xperia logo then black and back to the Sony logo... it is doing this constantly I can't power it off or interupt the cycle.
Power and volume+ resets but it just keeps cycling... no other buttons or combinations have any affect.
Connecting to SUS wont work either....
Any ideas?
Charge the phone for 1 hour,force shutdown(power button+vol up until the phone vibrates 3 times).Repair with sony update service:
http://www.sonymobile.com/gb/tools/update-service/
Tried the 3x forced shut down, but unable to connect to sus as the vol down/ pluging doesnt initiate the usb connection.
Assume i need to let the battery exhaust completely but its starting to get extremely hot.
SUS needs at least 50% battery to be able to perform the repair.
Its fully charged, has been on charge all day and was on charge during the update.
You should visit a sony service,an update failure(cable disconnect,power outage etc) can damage the device:
http://www.sonymobile.com/global-en/support/contact-us/
