I hate to say it, buy you may need to perform a software repair on the device. I have supplied instructions below.
1. Download the PC Companion software from PC Companion and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
let us know how you get on.
Settings-apps-all-sound enhancements,force stop and clear data.Restart.
Hi monofer,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you try boot the device in to Safemode, this will let you know if the issue stems from a third party application.
If it is, then you would simply need to go through any downloaded apps and try clearing the data or uninstalling them.
4. Start.
5. Repair Phone
6. Continue
8. Next
9. Wait for prepare
10. Select Phone
Sorry for yesterday's comment. After some additional adjustments... it works! Thank you for your help.
I have the same problem! Loudspeaker does not work. I did all the software repair steps mentioned above and nothing happened.
"Monofer" what additional adjustments did you take to make speakers work? please help I am desperate
thanks
i have had this problem and all i did was take the casing off and turn it on and off it worked for me.
