I have updated my software to 4.3 two days ago and since then phone is restarting every minute. Tried to use update service to repair and It started working well but the day after again the same situation. Could you please advice what should i do?
Thank you.
i have same problem here. :((
same here my phone is continue restarting. pressing volume down while inserting usb cable into computer and the light indicator turning charging indicator instead turning green light.
should this be done on a pc or phone?
