I have updated my software to 4.3 two days ago and since then phone is restarting every minute. Tried to use update service to repair and It started working well but the day after again the same situation. Could you please advice what should i do?
Thank you.
So, guys, I've visited the shop where I bought the device. They told me I have to send it to Sony for assistance, it will takes AT LEAST 1 months in order to get the cell back.
Now, what should I do in the meantime? I need my mobile for my job.
I think Sony should give a courtesy phone (Xperia T is not an entry level mobile phone) otherwise I have to buy a new, functioning, device and, you know what?..... I'm not gonna buy a Sony anymore!
Same thing happened to me. The phone has been in for repair for 10 days. Not buying a Sony again.
I have the same trouble, someone calls, take phone out of pocket and it goes into restart. Pick up phone to take a picture.... goes into restart. pretty much anytime I want to use the phone it goes into multiple restarts.
It's hot in my pocket quite often, and when it does work it's generally slow to respond and hangs. if I ever want to take a photo the moment is gone by the time it's ready.
I've have Sony Ericcson for years but since dropping the Ericcson I'm not impressed. As stated above this is not an entry level phone. It cost a bomb and I expect a lot better. It's already been back to the shop for repairs twice and looks like it needs to go inagain.
Thankfully it's still in warranty but that's not the point. This is the most unrelable handset I've ever owned and has made me think twice about another Sony come renewal time.
Hi
You'll be happy to know that I figured out this problem after a lot of frustration!!!!!
This was solved by removing the extra 32Mb SD memory card. For some reason it does not sit properly anymore in my phone and when inserted causes it to restart. When I remove the card, it works fine. When I put it back in the phone it works for usually a few days and then I have to take it out again and re-insert. Not sure if the problem is with the memory card or the phone, as it works now most of the time ok without restarting.
Hope it works for you!
