I suggest that you clear data for the Walkman application via Settings > Apps > Walkman > Clear data. Otherwise, have you stored music on your internal storage/SD-card? You can always try to move the music to the PC to see if you can open the Walkman application without the music on your phone.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Could you please elaborate? How do you mean that the Walkman application does not work?
Regarding the touch issue, I suggest that you boot into safe mode to see if you experience the same behaviour:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
