Its not so hard to replace the screen, but before you take it in, make sure that you tell them not to factory reset your phone at all
Sorry to hear that but you won't be able to access the pictures in the Internal Storage unless you unlock the phone
If its a hardware issue, I suggest that you DIY, replace the screen and you should be able to retrieve your photos
