x
Xperia SP hard reset problem
ugurkaya
Visitor
Hi guys, I have got a problem with hard reset (volume up+power key combination). It does not work at all. I've waited pressing these buttons for about 1 minute and nothing happened. Also tried this when screen locked, when unlocked, when phone switched off. No change, no effect.
Tags (2)
23 REPLIES 23
Alexander1
Champion
To soft reset an Xperia SP you have to remove the back cover of the phone. Then press the 'OFF' button with a tip of a pen (or something similar) for about 5 seconds.
Amal1XSP
Visitor
The back side button to Hard reset isn't working either. The better solution is to remove the SIM Card and the touch screen will work (Incase touchscreen wasn't responding before) and then insert the screen and use Power off button & select the Power off option on the Display screen. Hope this helps.
Parthsinhgohil5
Visitor
hey buddy finally igot the solution
for hard reset...there is a different trick for reset...
1..open the back cover
2atthe bottom u see OFF ...
3 with match stick u  have to hold down the hiden button
RatheeshKS
Visitor
Xperia SP comes with a non removable battery.So turning off in this condition is not possible by removing battery.The volume up+power button doesnt work in Xperia SP unlike other phones.The solution is given below.
  • Remove the back cover of Xperia SP and look for a small yellow dot on mid bottom with “OFF” written below it. Check the image below.
Xperia SP Heats Up Goes dead - Won't Turn On or Charge - SOLUTION
  • Now “Press & Hold Down the OFF Button, using a tip of pen or any other pointed object for around 10 seconds”. Phones vibrates and will be switched off automatically. Check image below.
P.S. Don’t use very sharp objects as it may damage the OFF Button.
How to Turn On Xperia SP after it goes dead because of heating - won't charge
  • Now phone restarts.
After restarting we found that our Xperia SP got back to normal temperature and everything was fine.  Slightly_smiling_Face We were able to charge our Xperia SP again, device was cool.
I also faced the same issue and got solved with the solution given above.Hope it will work for you also
kornell25
Visitor
Saludos amigos , mi problema es que despues de instalar una app "audio beats" se reinicio el telefono y como veia que no era lo que buscaba lo desinstale y se reinicio aparece el logo de sony llega hasta la pantalla de inicio y de ahy se vuelve a reiniciar y ha entrado en un bucle de reinicio de nunca acabar, por favor necesito una ayuda de como volver a usar el telefono
zulhamizan98
Visitor
So will this soft reset erase your data just like the factory reset?? And can do it if this phone facing with hang issue??
Ashroft98
Enthusiast
zulhamizan,doing this hard reset will NOT erase any of your data.It just reboot your phone.Yes,it can be used to solved hang issues.Mainly,it was used to free memory(RAM) used from RAM-hungry apps.
zulhamizan98
Visitor
so doing this often wii cause any problem to ths phone??
Ashroft98
Enthusiast
No,it will not have any side effects even when it is done frequently.
