Hi friends, I have xperia spin've identified the problem in the light of the display screen backlight is going to be flashing intermittently and continuously continues for 1-2 seconds. How can I fix it?
Restart your phone on safemode and check if you experience the same issue
if you do, you could repair your phone with SUS
Bridge (for Mac)
Alternatives on How to backup Xperias
If you experience the same issue even after SUS then stop by a Xperia care center
4.3 update did, but the problem still continues
Turn off auto brightness. Sometimes that causes flickering.
If that does not work, you can re-install the firmware or send it to a repair center like the above user said.
Auto brightness AND dim setting cause most flicker. If you adjust it to half way or brighter, it may flicker less, even with auto brightness. Turning auto brightness off should stop flickering.
There's an issue there, the auto brightness shouldn't behave like this.
I'm getting off auto-brightness and raise the brightness flicker is more obvious. I think the right solution to the repair center to send
