PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!.. It has been a long day, and it's only 2:49 pm.
I wanted to flash a rom this morning so I booted into clockwork mod, backed up my rom.
Cleared all data by factory data reset, wip cache partition and dalvik cache on my Xperia S.
(I unlocked bootloader last night) and flashed doomlord's rom and google apps add ons.
The phone reooted, and that was the end of it. Ever since then I have TRIED everything I can think of!
The problem is the phone only boots to the Sony screen, no Xperia screen after that, just a blank black screen,
and then it turns off. I can get it into bootloader and Flash by pressing the volume up or down key
while inserting the usb cable. The light will turn green, or blue.. But inevitably about 8 seconds later
the light turns off and it powers on. The computer in device manager doesn't even recognize the device is plugged in!
I can't use flashtool, or SUS, because when it gets to the connect your phone screen, MY PHONE won't connect.
I'm really afraid I just ruined my $400 Xperia S pone I bought off Amazon..
Hey bro... I realized that I had grabbed the wrong usb cable! Once I realized that I found the right data cable and was able to restore the phone through flashtool. So make sure you're using the right cable, that you've tried other usb ports, and that you'v tried other computers.
Best of luck!!
