when i am inserting usb flash drive to my sony xperia U via otg cable,its showing a message that the device has been disabled as the power consumption of the device is too high...is this my phones's problem or my otg cable's??
try a different brand but I doubt it'll work , you should use something like this instead
yes, it requires too much power, it's not going to work with USB OTG
i thought of buying OTG cable man....
wat way i can use memory card???
as an extra storage for movies or extra pictures
Don't forget to mark theCorrect Answers & Helpful Answers
it is a flash drive problem ! some of them (eg transcend with lower GB capacity consume less) so better to try good brand of usb flash and keep power connected to phone while connecting usb as a precaution
Actually it is not always the USB that is the problem, often it is the software on the phone
Workaround: Use more power from the phone (the irony)
-Plug in a USB hub
-Plug card reader or USB stick into that
Seems to work, when I have this error. Maybe this syntex problem should be fixed with a patch in the future?
