Hello all,
I have problems with touchscreen when charging, HDMI connecting or sometimes in normal use (but helps power button off/on screen). Touchscreen recognizes "invisible finger" and starts automatically "pushing" everything. What problem can be?
And next little question, when Jelly Bean roll-out for Xperia S? Now planning to roll-out Xperia P, Go and then Xperia S?
Thanks!
you should repair your phone with
SUS
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
it seems that the Xperia S roll out will be in few days
as the touchscreen issue
do you have a protective film (extra) or protective case?
No I dont have screen protector but preoder it from ebay. This protective film helps for touch?
SUS
