my xperia s is aways pausing for itself when i play a heavy game like modern combat 4 how to fix? it was only doing that today i got the phone on the 28th december please reply
ok i disabled them i am testing the phone now
if that doesn't work then > uninstall them > restart your phone > try again
ok right now it works great again thanks ! i'll write back if i get any more bugs
cool, most of the time the issues are related to other intrusive and/or poor coded apps.
Uliwooly,
im using AVG antivirus software in my Xsl.other than this im nt using any task killers etc.should I uninstall the antivirus.is there any problem without having antivirus.
Sorry for my poor english.thanks in advance
I would suggest that you uninstall it, you don't need antivirus, this isn't PC
there aren't any virus on Android, also if you donwnload apps from the play store you should be ok.
I can not turn my phone off and did not advance the flashing arrows marked corrupted repairman told her the boot device only sound comes Connectivity Standby light turns red, please help me
