I updated to ICS today.
Apart from the Storage Problem, my camera does not seem to work at all.
When I press the physical camera button or go into menu and press the Camera app button, it would show up as Camera Not Available.
Are there anyway to solve this without factory reset?
Thanks.
the Xperia S running ICS has a backup & restore app, so you can backup pretty much everything
also check the suggestions above
unrelated topic, if you have some time please check this thread
backup all your pictures, videos and music and clean/wipe out the internal memory
settings > storage (scroll to the bottom)
it seems that you probably disable an app and that's why its causing this problem. repair your phone with SUS and try again if it doesn't work then try the above suggestion
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
I tried factory reset. It's working now.
But I backed up my phone with PC Companion. Apparently, it backs up your photos, videos, msgs but NOT contacts.
I can't believe it, Sony!!!
