I purchased Xperia S a month back with default ROM GB, unfortunately i clicked ICS update and my phone got updated to ICS. But after update ICS have too many bugs like delay in opeining Dialer, wifi problem and the main Proximity sensor missed to get active in 2 calls out of 50 calls. This problem occurs twice in 50 calls. I had been following up with Sony service centre, according to that degrade to GB is now discontinued and cannot be happen, as these problems were not there in GB.
Please help me to resolve the issue to how revert the original GB rom
If you have unlocked your bootloader then you may void your warranty according to Sony's site
When your bootloader is unlocked PCC and SUS will detect modified software and fail to update.
Re-Locking your bootloader will allow PCC and SUS to updateyour phone
Thanks for posting and welcome to the forum!
Sounds like it would be wise to try performing a repair of your phone's software.
You can easily perform the interaction with our program Sony PC Companion, availalbe for download from the link below.
http://www.sonymobile.com/gb/tools/pc-companion/
The Xperia S is not possible to "downgrade" to Android 2.3 after an update to Android 4.0 is performed I'm afraid.
What do you think about this forum? Let us know by doing this short survey.
Thanks Peter,
I tried thrice by repairing from the PC companion and from service centre also. The problem is still there.
Suggest me for following
1. My bootloader is unlocked, so can I install GB manually, without effecting warranty
2. After updation SI number doesnt matched the back panel and firmware
3. Any patches available for ICS
Harpreet
If you want to downgrade but don't know how then see the link below - Ignore the title debrand it's the process that you need
http://www.xperiablog.net/2012/03/26/debrand-your-xperia-s-tutorial/
Now firmware or Rom which would you need ie:Country and Version .75 etc
I have quite a few and may have what you're after
I recently purchased a sony xperia s in aug 2012 and since its purchase i am having issue with the timescape, specially facebook inside xperia.
Leave apart the time scape log thing , it only worked when it felt like but built in facebook is also giving me a lot of problem.
it has happened quite often that it stoped working on its own,but being little skillfull..:):0 i managed to run it somehow..but it has now outskilled me.
whenevr i try to add a fb, account in timescape..a fb window pops out for jst 2 sec and then dissappears, and i am not able to link my account since last 2 weeks. hav forcibily stopped the application and tried again ,,but no results. hav searched the web regarding this problem..doesnt seems to b a popular one but yes 4-5 such cases exist...so lemme tell u that this problem really exists.
kindly help.
thannkz
My andoriod version is 4.0.4 and build number is 6.1.a.0.452.havnt done the recent system upgrade coz already some bugs r there.
Thanks Thommo
I need the GB ROM, if possible
Here's the UK Gingerbread Rom - This was the last Rom before ICS was released
If you prefer another countries then please say and i'll see if I have it
https://docs.google.com/open?id=0B-yM_qnM8ZPRcmhjc3JpUElHM0U
I need INDIA
Thanks bro!
One thing more to confirm that after manual degrade can this possible to upgrade (GB to ICS) through PCC or SUS, which may not effect the warranty
