My Xperia S current build is 6.0.A.3.7.3
The latest available software is 6.1.A.2.45 released on 2012-09-03.
However, when I try to update through PC or Phone Wireless, it advises me that I have the latest software, whcih I clearly have not.
Can anyone help? Thanks.
use this :
http://www.sonymobile.com/gb/tools/update-service/
don't forget "correct answer" if it works with you
use this :
Good tips by Mohammad.Qawasme above.
Try out Sony Update Service and hopefully it's able to sort it out and your able to perform the update!
What do you think about this forum? Let us know by doing this short survey.
