Heya,
Today when i connected my xperia to the pc it told me it needed an update so i went ahead and ran the update while i was playing skyrim and when i just checked it my phone was off, now it wont connect to pc or turn on
when i turn it on i get the sony erricson screen then a screen that shows a white traingle with a yellow ! in it next to a picture of a phone and tent he handsets switches off
ive tried taking out battery, taking out memory card, and sim and nothing.
Any help ?
you have few options
1) use Update Service
2) contact SE and send it in
3) use Flashtool
thanx will try that now
