Hi, sorry for my english. I have Xperia Pro build .62 with root but booloader lock. Is it possibile to install kernel for overclocking?
check the XDA forum, you will need to root your phone to overclock
Don't forget to mark Correct Answers & Helpful Answers
I have root!!! I need kernel...
if you have "root" why do you need the kernel, and which kernel?
Xperia Pro MK16i/a 2.3.4 update 4.0.2.A.0.58
http://talk.sonyericsson.com/thread/29687
?? with kernel stock I can overclock cpu at 1.4 ghz for example? Kernl stock has module for overclock?
