how's know what's the orginal upload firmwarer xperia p which's come with the phone the company version ?
you have to be more specific, do you want Android 2.3.7? or do you want an specific 2.3.7 (for your country and/or carrier or SI number?
if the later then check the XDA forum
unrelated topic, if you have some time please check this thread
if you want the global generic 2.3.7 then
click here
http://talk.sonymobile.com/thread/41609
and downgrade
I just update my xperia p on the sony mobile website and I get android versiob 4.0.4 build nember 6.1.B.0.544 but I found the original version which's come with the phone at the begining it was better more than the new one and the problem that I don't know what's the original software version which's come with the phone
The original firmare was 2.3.7.
which issues do you have? be specific
