Xperia P no function - black screen
ROZWIĄZANE
Shimmy
Początkujący
My Xperia P is 12 hours old. I have made a few calls and added a couple of apps.
I went to upgrade to ICS but the PC companion froze at the point where the phone needed to reboot with 50% battery.
Since then I have a black (backlit) screen. No other function.
I can reboot with [power]+[vol up] but it reboots back to the same black screen in about 1 second.
I can force a power off with [power]+[vol up] held until I get 3 vibrations. Same black screen when I power back on.
Any suggestions before I take it back to be replaced?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Shimmy
Początkujący
Got it working.
Hold down power and up. Wait for the single vibration, keep holding until you get the 3 vibrations and the handset will power off.
Plug it into the computer and run the upgrade process with it turned off (ignoring the instructions to turn it on again).
I'm now happily running ICS.
Wyświetl rozwiązanie w oryginalnym poście
14 ODPOW. 14
M_qandil
Początkujący
I have got the same problem with my new s while updating any help please?
nabendu
Początkujący
Turn off your phone, hold Volume Up and connect the USB cable to the computer. If the LED light turn blue that means the phone is now on Fastboot mode. chk if dat is working
Shimmy
Początkujący
Got it working.
laurentiu
Początkujący
Can you help my step by step because i don't speak english very well?? I have the same problem and i don't know what can i do :smileysad:( i'm unfortunate
profile.country.RO.title
_alexdon_
Expert
For the phone to turn off,you need to press power button+volume up,until you feel the phone vibrating three times.Connect to your computer and upgrade with pc companion,following the steps provided there.
alexdon
laurentiu
Początkujący
thank you so much Slightly_smiling_Face
laurentiu
Początkujący
do you think it will work???
_alexdon_
Expert
if the user above said so,you should give it a try.
alexdon
suyyagh
Początkujący
my phone's screen stopped working though the touch is working i can answer calls and unlock my phone because i memorize the pattern but the screen is black, i tried connecting it to the compuster but it wont detect it , (xperia P) please help me
