the xperia p white paper provided is showing that p is having adreno 205 gpu; but other sites are stating that it is having mali-400 gpu.....
what is the actual gpu.......???
and someone please tell is there any difference between bluetooth2.1 and 3.0;
P is having 2.1 whereas samsung galaxy s advanced is having 3.0;
will it make any difference.......??but i know theoritically speed of 2.1 is 3Mbps and for 3.0 it is 24Mbps.....
but practically will it make difference.......???
Yes... I faced that problem too with quadrant....Even Antutu flickers....Whats the problem with this phone...As some said i changed the font to normal in big font...Still persists...Any solution
difference between mali 400 and adreno 205? which is better?
so xperia p has adreno 205 in reality not mali 400 and adreno 205 sucks right?
it has mali400 multicore but with 320mhz instead of 400mhz...
so basically image rendering of the xperia P while HD gaming is poor? lags when playing HD games.
Antutu flickers??
Remove the preinstalled BigFont app... It causes problems with a lot of apps... Some games dont work and etc
Try it
Hi all,
I am a kernel developer (on xda username nickholtus) for the xperia P and i can tell you the xperia P is using the mali-400 gpu.
when i compile the kernel it includes the mali-400 gpu driversa and n not the adreno one so it MUST be a mali-400 gpu
Hi all it is confirmed that Xperia P has an ARM MALI 400MP GPU its confirmed. the whitepaper has it printed wrong
now i want to know that the GPU in galaxy S II is also ARM MALI 400MP and it is said in all the tech websites that this GPU is more powerful than that in Sony Xperia P's ARM MALI 400MP is it true ?
my next one is how many cores are currently housed in Xperia P GPU ARM MALI 400MP ?
Xperia P has a single core mali gpu,while SGS 2 has a quad core mali gpu.
