Can smbdy plz tell me how to reset my camera on factory setting. I have changed the setting and NW my pica are not icing that much clear.
that's quite odd, you might want to take your phone to a sony repair center.
Settings > apps > all > camera > clear everything
Don't forget to give Kudos
Setting ----> Apps ------> All -------> Camera
or repair your phone with either PCC or SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
still same problem, pic are not as much clear as sit ws earlier.
pic are bleard frm corner and clear in center point.
wt is tis ?????
It could be that the lens is dirty or it could be that there's something bouncing light from the flash or a protective case or protective film covering or too close to the lens
i have checked everything dear lens is not dirty, evn though i cleaned it again, and i m not using any protective case or protective film either........
Do you have a custom ROM? could you post some pictures so we can all see the problem?
