@Krish310594 - Then you would be best to contact your lcoal Xperia care team for assistance in arranging an assessment of your device.
What are your thoughts about this forum? Let us know by doing this short survey.
Hey Guys,
I've been using my Xperia P from last 1.3 yrs. I was also facing battery drain problem like any other user of xperia P. I'm constanly looking for any solution from this forum. but nothing helped.
When I woke up this morning, I noticed my mobile battery has become fat and it stretched the screen out of phone assembly (like curve) :-(.
Please suggest what should I do?. My phone warranty got expired 2 months ago. Do I need to replace my battery.
My phone uses: Li-Polymer batterry * 3.7 V - 4.2 V
1265m Ah battery
Can I replace the battery with 1305 mAh?
What is best solution?
take your phone to the nearest SONY service center. a lot many Xperia P's have had the battery bulging issue. i suggest you get it checked.
