If it woks on other phones then it should work on yours too...try a repair using PC Companion or RESET the phone...
Repairing using PC Companion is NOT flashing...
Reset is NOT flashing...
I guess in my simple English I said 'IF' there is an option which works on 'other handsets' (other handsets probably doesn't mean your non working handset) then it should work on your SP too. BECAUSE SP isn't from Adam's age.
I wouldn't comment on your 'readng first and then replying' comment!
hello there i am not be able to send an audio message using apps (facebook messanger , whatsapp) in my xperia t when i am try to send he said " can't setup the recorder now please try again later " what should i do ???
hi i'm experiencing this problem as well. how did you fix it? please reply asap
thank you!
