Using Miro for last 2 weeks.
3 Issue...3 queries:
1. How to forward a text message?
I am clicking on 'forward'...its opening up the address book ...fine....either im choosing one from the book or doing a manual number entry...then? then what? the screen is stuck there only! Its not going forward to the screen with 'Send' button. I have to kill it...then again openng the text app...finding the last left text as a draft..and then sending it. Its irritating.
2. How to download multiple file attachments from mail (email client OR the default gmail client, both).
Suppose i got a mail having 5 image attachments, I am unable to find the option where I can download/save all the files in a single go...rather I need to click on each of them. Any shortcut?
3. Quite often, in a rampant way, the mob is unable to access/find the files of SD card, as a result, gallery not showing anything, walkman cant find any song! Horrible. And a restart is not a solution here (I expected so) , tried that many times, it gets fixed on its own, sometimes within mins, takes hours at times. Any solution?
Thanks.
After you tapped Done you should get back to the 'normal' text message-window, with the message pre-written in the input field at the bottom and the contact you selected at the top. All you need to to is hit the send-button to send the message.
1. When forwarding a text message you open up the conversation, tap and hold on the message you want to forward, choose forward message. Here you have two options, type in the phone number in the box at the top or tap the small box to the right to open contacts. When you chose a contact by checking the small box to the right, you have the option "Ready" or "Done" down to the right.
2. As far as I know, this is a limitation in Android and Gmail app. You have to click each file to download the files.
3. Is the SD card you use in your phone a new one or have you used it in some other phone before? If it's a card you have used in another phone you might need to format it to get it to work properly. If it's the card that was included with the phone, it seems to be something wrong with it. Have you tried any other cards in the phone to see if the problems persist? This to rule out if it's the card or the phone that causes these problems.
1. Okay, but what after that? As I told you earlier....it does absolutely nothng after tapping on the 'Done' button. It doesnt get stuck or hangs as such, it just stays in the same page/screen.
2. Okay. Thanks.
3. This is an old one, I will format it and will let you knwo.
Well mate, I repaird the phone again...and bingo..its working the way u told!
I am still to check the formatting thing of SD card.
Thanks
Things are working.
Thanks
Great, I'll try that, too.
Why can't I prewiew attachment in gamail?
It says "no app can open this attachment for viewing" when i hit the attachment. but which i app should i download or use?
I've tried several app from playstore, but doesnt works, I just want to preview, not download.
