my xperia mini keeps turning the screen on by itself and it really bothring me it happens every 10 mins and it do it couple times on row every 5 seconds please help me its really annoying?
please notice it happens before and after ICS update
uninstall mcafee as well and if the problem persists repair it with either PCC or SUS
I've seen this and the problem was an app
taskiller
antivirus
battery app
uninstall them and check again
I have mcafee antivitrus the one came with it and all battery apps deleted i will check
and thank you for ur fast reply
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
i deleted it and still happening ! i guess im gonna try the other way
keep us updated
it seems to be working fine
thank you
