hi the main problem is in prepare when i get "instalation error"
should i maybe try it on another pc?
use this instead
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
use this instead
you can also try it by turning off your firewall and/or antivirus
or
restart your PC -> press F8 -> safe mode -> run either PCC or SEUS
You can read about Android 4.0 here
http://talk.sonyericsson.com/message/140370#140370
SE insult early 2011 Xperia customers
