is promptig every time.
Please Help
try SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
try SUS
Thanks a lot, UliWooly!!! My Mobile Ui is gr8 now and feels good to use it!!!
Anytime
check this out
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
thank you a lot uliwooly, i fallowed your instructions and i updated my xperia mini pro to ICS with SUS, BUT, today i connected mi xperia into my computer and the pc companion doesn't recognize my cell phone, i tried to get into the SD card because i needed a picture and i couldn't access to it, please do you have any advice in order to resolve these kind of inconvenients.
thanks a lot!!
turn off your antivirus and firewall
than you!!!......you save me ......sorry to bother you, just 2 things more
1.- Do i need to turn off the antivirus and the firewall when i want to use Pc Companion?
2.- my SD card (2Gb) now its almost full, thats for the update? so that do I need to buy a bigger SD card?, or its just need to be formatted?
thanks again for helping me out.
you can add them as an exception
the update it's not installed on the SD card. only pictures videos and heavy games
- Thread moved to the correct community -
