It seems that the Xperia goes into some "deep sleep" after a while of non-usage. Typically an hour or so. The only way to start the thing up is to remove the battery??? We have installed latest updates, switched SIM cards, but no result. The phone is completely useless. It is a shame.
Hi, see if it helps
Backup everything on phone memory as the process would erase all
Update/Repair your phone via PCC OR SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
Hi, see if it helps
or
